Dear Community,
Let's work together! BIM is the word and in Europe the legislated standard for information transfer is IFC. Most softwares of note can export IFC models. Most softwares of note can import this data-filled information and graphically display it. Which softwares, if any, can take a general imported element and transform it into a System Native element. For example, I import a pipe section. The geometric parameters are displayable. We can view the other parameters like material, diamter, start and end point, wall thickness, etc. When will Revit be able to take this information and replace the wire-frame CAD with a Revit Pipe Object? Is anyone working on this technology?
Best regards,
Jean
Best regards,
Jean
