Showing some but not all view titles
    I've created a "View Title - not seen" family, inserted in a project. When I click (no) on the visibility all others turn off.
    Anyone know how to show some view titles, but not all of them?
    Trevor Pan
    http://www.trevorpan.com
    What do you have the other view titles named?
      Hi cganiere, just these two. I was hoping creating a different one would allow me to only turn those off. Have your run into this issue?
      Trevor Pan
        Also, just tried removing the titles in the "Not Seen" family. When I imported they did not show.
        However, it seems, if a drafting view title is changed to "Not Seen" they all change to not seen. Is there a way to make them instances? I have some drafting views for notes, and want a special header that doesn't have the view title look.
        Trevor Pan
          Here are some snap shots of what I have: view port.JPGVT.JPG
          One is the viewport - each detail on the sheet should have its own "view port" and you can switch between types. In my case I have five types.
          The other is a snap of my family browser - here you have the view reference family w/ view title families shown below.
            cganiere,
            You've solved the issue. Man, even after several years still get caught up in things like this.
            Thank you ~
            Trevor Pan
