I have a door frame family with a transom that I'm nesting into my standard door family. The glazing of the transom is showing up in plan views, even if the view range isn't cutting through the glass. I've loaded the family into a blank project and am getting the same results.
I have a similar family that I made in the past where I set the extrusion for the glass to not show when cut in plan/rcp. However, I now want to see it in my RCP. I have attached an .rvt file with the family loaded in. Any thoughts? Thanks!
