Revit Pipes in Navisworks
    For some reason, pipes are displaying their material properties. Copper lines are showing as copper, cast iron is black, and my Appearance Profiler isn't able to override that.
    Also, I don't want to see grassy green roofs, textured brick, etc. but these are all showing too.
    Has anyone encountered/figured this out before? I've seen this happen to someone else.
    EDIT: Never mind, I just changed the Viewpoint mode to shaded.
    What, changing the visual appearance to Shaded (as opposed to Full Render)?
    No, I would never have thought of that.
    [sarcasm-mode-off]
    I dream of the day when I can complain about MEP models with (correct) materials... Consider yourself fortunate.
    [/sarcasm-mode-off]
      Always a pleasure!
        Originally posted by snowyweston View Post
        Always a pleasure!
        [ATTACH=CONFIG]29498[/ATTACH]
        Sorry I didn't see your post snowy. I stayed on the OP and went searching, then when I found it I switched tabs back to the forum to delete, but since you can't delete, I just edited. Thanks for chiming in though. Trust me if I saw your post I wouldn't have ignored it. Cheers,
