Building Coder: RVT Properties to XLS and Forge Accelerators
    Are you interested in easy access to your Revit model properties?Well, you can have that even without a need to install Revit.The Forge Model Derivative API extracts a streamlined copy of all geometry, BIM element hierarchy and properties from over fifty file formats, and Revit RVT files are just one of them.Augusto Goncalves implemented a Forge sample to read all the properties on all BIM elements in an RVT file and export them to an XLSX spreadsheet Test run it yourself Source code on GitHub...
Loading...
