Print issue with oversized paper
    Hello everyone,
    i have problem with printing from Revit with custom size. In office we have HP Designjet T920 HPGL2 (paper is 914x2000) and every draft has been cut out by edges when I print from Autocad. But when i'm printing from Revit there is problem beacuse plotter won't cut paper by edges. Instead cutting edges, from plotter came out full size of paper (914x2000). Also when I put draft in PDF, I can't remove white margins with Adobe Acrobat Pro.
    There is plotter properties.
    Thank You for helping.
