Hi all!
I've been trying to wrap my head around the difference between saying something like 36" CLR versus 36" MIN on dimension strings, but I was hoping someone here could explain it clearly to me. Someone explained that using "CLR" denotes that there is a requirement of some sort but "MIN" simply means that that's a minimum. In my head, in both cases, it stands that when you use either, it means that there is a minimum required dimension but it can be longer if there ends up being extra space.
and then there's...MIN CLR? Eek, the more I try to reason and think about it, the more confused I get :hide:
Thanks for the help in advance
