If you use the insert from file command on an older project does it permanently upgrade the file?
insert from file on older projects
No, it temporarily upgrades it, which is a colossal waste of time. If you go back for a detail ten minutes later, itll have to upgrade it again.
Plus, i would recommend never using that feature and pulling details from *other projects.* If the details were worth keeping, i would hope a BIM Manager would extricate them from the project and put them in the current versions library.
I've been converting our AutoCAD standard details to Revit and finally got the okay to deploy them to our library. There are a lot of them and I did it...September 11, 2015, 11:34 AM
We are trying to implement Revit as our office standard for our BIM platform. One question we have been discussing is how details (greater scale than...June 5, 2014, 08:31 PM
I am in the process of Creating a Typ. Detail Library.
and I am not sure this is the right way.
I have converted all the Auto Cadd...June 7, 2011, 09:10 PM -
Guys,
about to start a Gigantic project.
-three buildings, all same program multi-family one 34 story highrise and two 6 story mid...January 22, 2016, 02:32 PM -
What are the best practices your firm uses to manage an office detail library?
1. central detail files with all details that users insert...April 16, 2015, 01:50 PM
Monumetric Footer In-screen
