Hello
While designing a panel for parametric surface some question raised
Could it be possible to “link” dimension of the panel using IF “IF (<condition>, <result-if-true>, <result-if-false>” condition to its material?
What I want to achieve is logic condition IF size (reporting parameter) of the panel is bigger than (value) then change its material to red
Thanks for all hints
