Hello.. I am new to revit... I have a question.. is it possible to make a wall made of clay blocks (for example Porotherm blocks of a certain dimmensions).. alogn with vertical concrete beam (I don't know the right english term for this but that is why I am attaching a picture..hope this can be made in revit, it is such a standard thing in construction
blockwork wall
I don't see a vertical beam in your image. I see a column placed at the corner return of your block wall. Is that what you're talking about? Is your question how to incorporate this column into the wall type. Is so, not with a basic wall type. With a curtain wall type you could. But, I wouldn't. I'm assuming that these are structural columns and so I would model them as such. Separately.
p.s. any right angles in this building? I don't see any in this image.Last edited by Barth; February 25, 2017, 07:35 PM.
Hi, after the Autodeskl training I'm now an avid Revit 2014 user of Archuitecture. I have a problem in that I can't figure out what to do about external...July 26, 2013, 03:34 PM
Is there any way to create a boundry wall like in attached rvt with wall/ curtain wall/ Line based family
LJU...-
September 11, 2016, 07:06 PM -
I am drafting from a very old hand drafted pdf drawing, refer attached clip 1. As the clip 1 shows, I need to create a cavity wall which...-
Channel: Out There
May 25, 2018, 09:21 AM -
Hello Friends,
This is my first post.
I had a quick search but couldn't find similar result for my problem.
A-) I try...September 22, 2013, 09:07 PM -
How can I clean up this wall condition. I wish the horizontal interior stud (single wall type) to come across to the window. The vertical wall is a wall...March 27, 2019, 07:57 PM
