Revit - Not getting flow rate in AHU duct supply and return.
    Hello everyone . I am a newbie here new to this forum. Please help me with this small issue . I have attached my revit project file. Im completely new to revit , just installed yesterday. I cannot get the flowrate in the main ducts TO and FROM the AHU. But I am getting flowrates in all other branches .
    Link for the project file :
    A help will be greatly appreciated
    长丹├┤'仈 . 丁〇긴ㄈ├┤ . 丁├┤工己
    Please open the above file as project file to edit and see the things inside. I tried adding and removing the ahu to return and supply systems. any ideas?
      Checkout this image . Please tell me the flow connector config for AHU,VAV and diffuser connectors
        Problem solved . It was improper duct connections which was hidden . i used the check disconnects option in analyze tab
