I am trying to construct a bay window/turret for a residential project but I am having a hard time getting the walls to join properly. I have tried using the trim/extend command as well as working with the join options. Nothing seems to be working. I have attached an image, the red lines show how I want to join the wall.
Wall Join Issue (see attached)
This also happens when you have other adjoining walls above or below, perhaps they were drawn first then Revit is trying to maintain those joins. When this happens to me I isolate the walls in 3D to get a better view of what's going on. Worst case scenario you can 'disallow join' (s) and use the join geometry tool to clean it up again.There are no stupid questions, only stupid people
I have a wall that is joined to 5 other walls, and despite unjoining the wall from everything or cutting and re-pasting the wall it is still joined to...December 9, 2011, 05:58 PM
I've been working on a few projects lately (2013 - No Patches) where my plan views which once displayed my wall joins correctly, now do not. Sometimes...April 3, 2013, 10:58 AM
I have a problem with joining wall which is made of several layers, with concrete wall. In attachment is the picture of the problem. Does someone have...November 6, 2012, 10:39 AM
Any ideas how to join the walls at this intersection? I've tried using the wall joins tool and I tried creating a void extrusion, but haven't been able...November 19, 2015, 08:15 PM
Hi all,
I've come across an odd wall join anomaly - the attached file (RVT 2012) shows the problem. Essentially I have a junction between...April 16, 2013, 12:33 PM
