Does the 'Sill Height' value only report from the bottom of the opening cut, even if there is a 'Default Sill Height' dimension established elsewhere? I would like the sill height of my window to be higher than the bottom of the opening cut, is this possible?
As seen in the image below, Revit will only schedule the 3'-4 1/2" value rather than the 3'-'6"
thanks!
thanks!
