I am new to curtain walls and have tried to play about making my own custom panels. I've then loaded this into a brand new project, created a simple box mass, and applied a curtain wall system to the faces.
All I want to do is use my custom panels on the curtain system but I've no idea how. The custom panel shows up in the project browser, but I can't see anywhere where I can select my custom panels. If I select a single panel, I can change the type between: empty system panel, glazed system panel, and solid system panel. Nowhere does my custom one show up.
It's probably simple but every page I've googled trying to find the answer says you 'just select your custom panel' so I must be missing something.
Any help?
Thanks
Any help?
Thanks
