I am having a very odd issue with some B&G base mounted pumps. When I go to insert the pumps I cannot control what level it goes on or the offset height, they are grayed out. The only way that they will insert is on the edge of the floor, so they are perpendicular to the way they should sit and also where the walls run. Wondering if anyone has had this issue and knows of a way to fix it.
Micah
Micah
