I have a revit add in whose code I wish to view. I am relatively new to the API part of revit, is their some videos/documents showing how I can view the add in's code? Thanks.
View Add In Code
I want to know simple operation of a revit like cop ,past hiding code behind it. I try to make a looping system that help me in modelling in revit by...
Channel: Dynamo BIM
June 20, 2019, 08:02 PM -
Hi there,
After subscribing to DocumentChanged event, how could I filter for a view deletion, pop up a message (no problem here), and...
Channel: Third party Add-Ins, API and R&D
September 29, 2015, 01:20 AM -
.. so I posted about a prank about making the explode command in CAD play a sound through lisp and someone joked about doing it in revit .. I figured...
May 27, 2011, 05:16 PM -
I've been changing the transparency of a model in Revit 2014 using the ".SurfaceTransparency" property. Works like a charm,...-
August 21, 2014, 10:24 AM -
A colleague of mine pointed me to this website. It allows you to look through the following codes absolutely free:International Building Code...
International-
Channel: Blog Feeds
March 15, 2012, 01:45 PM -
