We have a situation where many of the walls in our project are structural elements and are part of a linked structural model.
The BEP protocols dictate that when sharing models, all links are removed. When we crate rooms with the models linked we can happily set them linked models to room bounding, but after they are removed and then re-linked after sharing, the rooms no longer find their boundaries.
To get around this issue we have had to use room separation lines extensively, something that I would normally consider to be poor modelling practice. For one thing, we need to keep the separation lines invisible in most cases and they cannot be locked to the RC walls so any layout changes will need to be manually identified and adjusted.
Have others experienced a similar situation and maybe developed a better approach? I'm toying with the idea of creating wall types to substitute for the RC walls in the structural models purely for the purpose of defining rooms in a way that eliminates the need for room separations, but this introduces other issues of course!
