All,
Long-time Autodesk user, new to Revit.
I can't edit wall location lines using the modify tool in the properties palette. No drop-down menu appears to select location lines from. (see attachment, left side) I can select the wall location lines when placing a new wall (see attachment, right side) but as soon as I place it, there's no modifying the location lines.
I took the screenshots Revit's sample architecture project file, but the problem occurs for me in all files I open. I'm using a 30-day Revit trial right now. Am considering whether to buy into a subscription.
All help is appreciated.
Cheers, rsrdencsu
Cheers, rsrdencsu
