I have a generic model and it is a Halo light essentially so it has a thickness. When I try add a parameter to this I can only set a parameter to one...
Hi there, this question seems easy, bu it isnt. I've created the CSV table.csv with all the parameters uasefull for my reduction idro-fitting family....
Once Project Parameter is defined is *** possible to modify it? For instance, Type of Parameter is greyed out - I suppose is not possible, but what could...
