We use instance parameters in our windows and doors to control the number of glazing rails within a sash, like an adaptive grid. This gives us flexibility during early design and we would prefer not to make a new window type for every sash pattern while exploring the design. The issue is that when using Legend Components to draw our window elevations Revit will only display the window and its parameters that were present upon FIRST loading the family into the project. Without having to purge the family and reload with the new instance parameter settings, is there a way to get our Legend Components to update??
The 3D view on the left shows the window and its current instance parameters (using a 3x2 grid for both sashes). The elevation on the right is legend component showing the default settings (when loaded). I have already tried going into the family, changing the instance parameters and reloading without luck.
