Our v2017 Revit.ini files are exhibiting odd behaviour. I don't know if this has just happened or whether it has been doing it for a while - because we rarely need to interact with our ini files.
Two things are happening:
* Our file histories are progressively being trashed. (The number of files listed is reducing over successive sessions.)
* If we use the Options dialog to edit paths eg. "Default path for user files" or "Places" the changes are good for the current session only. When we restart Revit these paths have either been returned to the previous setting or set to something completely different.
One user is getting a dialog box saying saying we should confirm that the file is not ReadOnly. They are not.
This is happening to multiple users in v2017. This problem is not presenting when tested on the same machines in v2015.
Have you seen this before? What could be causing this please?
Thanking you in advance.
Anthony.
Anthony.
