I have a couple vertical Ts that was draw on wrong reference level. Every time I try to change the reference elevation even changing the offset my Ts shoot to the air. Is there a way to change them without having them to move?
Changing reference level on vertical T.
Not that I am aware of. The offset distance is maintained when you change reference levels. You'll need to change the offset number or move the fitting back. Use the levels as your reference points (in a section or elevation) when moving the fittings back down.Last edited by kubsix; February 15, 2017, 12:29 PM.John Karben | IMEG Corp.
I found a python script on the Autodesk forums that fixes this problem. I had to install the Python shell and change the script prompt language from French to English. Worked like a charm.
[Revit] Change fittings reference level without moving it – Python HVACLast edited by TFuller; February 14, 2017, 02:04 PM.
Originally posted by TFuller View PostI found a python script on the Autodesk forums that fixes this problem. I had to install the Python shell and change the script prompt language from French to English. Worked like a charm.
-TZTannar Z. Frampton ™
Frampton & Associates, Inc.
Its possible without a program, just change the level and the offset at the same time. Before moving the mouse out of the properties (There is also a setting in the Revit.ini so that you have to click in the view before changes are applied) You can change the level of a pipe (without it moving...if only Revit was consistent.) to see what that offset should be.
If you are into Dynamo there is some discussion about this on there. Setting all elements in a model to the nearest levels would be a nice tool to have.
(With some rules, like if it is within -500 then it belongs to the floor above)."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Yep. If you can read some dutch.
https://sites.google.com/site/bimsta...vels-aanpassen"One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Hi!
So, the arc on the project I'm working on just decided to reduce the floor build-up by 40mm and move all levels (4) in their model. I thought...-
Channel: MEP - General
March 15, 2018, 09:47 AM -
hello
i'm using REVIT since fews months and that should explain the "level" of my question.
i searched on the forum but i didn't...-
April 27, 2017, 08:27 AM -
My question is one regarding approach, or procedure, more than a direct Revit function with Duct.
Lets say you have a four story building...-
June 25, 2013, 06:09 PM -
I am trying to create groups to model a common restroom core. I get my pipes and fixtures laid out and select them all and select group, name it and I'm...
August 26, 2014, 08:05 PM -
as title says and see snapshot; i know i can change one by one but is there a way to change globally? if i select all pipe instances visible in view,...
April 24, 2020, 05:43 AM -
