2017 added this menu after pressing esc from a text element. This drives me up a wall.
This text editor feature should be considered a bug
Drives you nuts how?
Note the Title on that dialog box: "Cancel Editing Text"
Pre-2017, pressing Escape used to blow you out of the Text command and throw away what you had typed or changed.
Now at least it warns you that you're going to lose something.
You're saying you'd rather have it lose your work without asking?
Clicking outside the Text Box has been the proper way to finish editing text since Revit 1.0Dave Plumb
BWBR Architects; St Paul, MN
Usually if I start making a no leader line and I meant to start a two segment I would just cancel and start the command over. Sometimes I'll also start one a realize before typing that I want a different spot. Now I have to press two buttons. I guess I never blew away an edit with esc that often for me to find it aggravating.Cody Rapai
Democracy At Work
I know too much about Revit to call myself an expert.
Yes, for me the problem with this dialog isn't that I want to click Yes or No, its that I know (well at least I use to know) that hitting escape would cancel. So now when I expect to cancel, just by hitting escape, I get this annoying dialog. Time to retrain that muscle memory. Although a basic ini setting would have been simpler.7
I've been working on my first R2017 project for the last few days and the dialog that pops up when I finish creating text is driving me nuts . Create...June 28, 2017, 05:46 PM
I read a post at AUGI tonight that mentioned using the Modify button on the ribbon to finish typing or editing text. The intended technique to finish...
Channel: Blog Feeds
November 2, 2013, 06:15 AM -
Long awaited, much rejoicing was heard when Revit users heard the news, there is a new text editor. Really? Can it be true? Yes they've revisited the...
Channel: Blog Feeds
April 15, 2016, 04:15 PM -
What controls whether or not Text Word-wraps?
Or more accurately, Letter-wraps?
I've got some Text elements in my template that...May 19, 2017, 07:53 PM -
Since I upgraded to 2018, the text works differently. With having to hit escape then getting a dialog box and having to click that....it just seems to...May 9, 2018, 01:48 AM
