Printing remotely outputs different PDFs
    If a user logs onto their computer remotely using RD Gateway, the PDF output is different than when printing in the office.
    Any suggestions other than using BlueBeam?
    Thanks in advance.
    Interesting.
    I had a user just last week that reported the same thing.
    Her Text got wider or bolder, or whatever that is, exactly like yours shows.
    However, it's on an older Remote Desktop server that's about to get retired, so we didn't follow up. Never found out why.
    But it looks to me like Arial Narrow got swapped out for regular Arial
    Dave Plumb
    BWBR Architects; St Paul, MN
      The solution is to install the Windows hotfix: https://support.microsoft.com/en-us/...sktop-protocol
      see also: https://forums.autodesk.com/t5/revit...p/td-p/6575672
      Last edited by Markus; February 16, 2017, 02:03 PM. Reason: corrected with proper solution.
