Building Coder: Setting Active View During Idling
    Here is a summary of the discussion and solution for [setting `ActiveView` during the Idling event](http://forums.autodesk.com/t5/revit-...nt/m-p/6848256) from the [Revit API discussion forum](http://forums.autodesk.com/t5/revit-api-forum/bd-p/160) raised and solved by Rudi 'Revitalizer' and Kinjal Desai, founder and fullstack developer at [Dwaravati](http://www.dwaravati.com): **Question:** I need to set `ActiveView` in `Idling` event handler. As per API documentation, this operation should not be invalid: no open transactions; `IsModifiable` is ok; `IsReadOnly` is ok; No pre-action events around. However, trying to do so throws an `InvalidOperationException` with the...
