Family masking region and room tag
    Hi!
    I have a problem with tagging rooms and family masking region - on some floors there masking region appears on some floor no... I have added some photos (one is from 1st floor and another from2nd floor) - exactly the same room tag and the same family... I need to add that I tried to change base and limit offset for room tag as well as for furnitures.
    Could anybody help me? Thanks!
    Hi kasiakasia, first try to have the same visual set up or template for both of your views, as I can see the first image looks like Wire-frame, second one looks like solid with edges, HTH
    E.A Poe
      Thanks a lot! It was the issue... Solved
