Mitre cut all around a flat roof
    Hi everyone
    I have a flat roof of a coolroom and I need to do a mitre cut around the perimeter of the roof. How can I achieve that? I tried by creating a model in place and after to cut the roof with it but it didn't work. I want to avoid making the roof a model in place. I prefer to somehow cut the roof if possible.
    How did you cut the wall? If you have your wall cut already, just join the roof and walls. Walls will cut the roof to this angled shape.
    But, why do you need that connection? It’s highly unlikely it’s going to be built that way.
      I tried already. Is not the roof that will be cut if I join them, is the walls. I need that connection because this is the way they going to build it, I spoke with the builder already, that's what he wants.
        Is this what you mean? I found this solution by using a mitered roof fascia.
          I can't clearly see what you showing there bud.
            This is what I'm trying to achieve. For now I've done it with Model in Place, but I would like to know if it is possible to achieve the same result with normal roof.
              Have you tried using ‘switch join order’ tool? It works for me. Fascia will work too, as per Barth.
                Now I got it. Yep, it did work. Thanks fellas! :thumbsup:
