I created a double acting door family with a swing angle parameter that allows the user to change the angle of the symbolic lines that represent the door swing in plan view. with the double acting aspect I have symbolic lines that represent the door swing in plan on each side of the wall. for some reason I cannot change the swing angle greater than 88 degrees. when I choose to go greater the family breaks and I get several error messages. I am attaching the family for your review. the family was originally built in revit 2015
double acting door family swing angle parameter
Take a look at this blog....should help ya out quite a bit.
Also, take a look at Aaron's doors... https://www.revitforum.org/architect...-v4-r2015.html and see how he built his.Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by Andrew K View PostIn addition to MP's post, your lack of reference lines to drive the angle parameter is what's causing the problem.
I have created a single door with a parameter to allow for a change in the swing angle. so I went on to create a double door with a parameter to allow...
April 27, 2015, 04:34 PM -
I am trying to create a double door family, where each door has its own swing angle. I need to be able to do this quickly. How would I achieve this? I...November 22, 2021, 02:43 PM
I'm just looking to create a simple 2D detail element of a bent steel angle. Desired instance parameters are length, width, thickness and degrees of...
March 12, 2014, 08:42 PM -
Hello all,
I am spending a lot of time to create double swings in a door family. Sometimes I succeed it by chance.
In a door family...December 12, 2018, 06:12 AM -
Ill try to explain this as best as I can. Does anyone know if there is a way to get door swings to appear at a 45 degree angle when they are inserted...
September 14, 2015, 08:22 PM -
