Accidentally the visibility color of the structural families got changed. i don't know how. even if i tried changing the material still the visibility color is the same. Can anyone tell me how do I solve it.
Structural Columns Visibility Problem
There are only about 4 possibilities with this problem.
1. as Gigi mentioned, someone has over-ridden the graphical representation in that view either by element, or by category.
To fix this, select the beam and right click, then select "override graphics in view" --> "by category" and reset any changes made.
2. The view template has changes to it. To see this, in the view type "VG" and scroll down to "structural framing" and see if there are any changes made to color here.
3. A view filter has been added. To see this, in the view type "VG" and along the tabs at the TOP of the dialogue box, look for "Filters" click on the filters tab and you will see if any over rides have been made. If there is nothing present in this tab, then no over rides are made.
4. Material appearance has been changed. As you already eliminated this as a possibility, you can move on to testing out the other 3. I would personally eliminate them in the order I listed them here.
I need to override the material that has been used in the structural engineer's model when the model is linked to my architectural model.
...June 10, 2016, 09:47 AM -
Hey guys,
I have a question about the visibility options.
I tried in this 3d view to uncheck alla the architectural elements....-
February 21, 2017, 08:52 AM -
Hi! I'm a brand new co-op student so please be gentle. I have been using Revit for about a week, but I was tasked with finding out why the new ductwork/piping...
Channel: MEP - General
May 31, 2019, 01:20 PM -
I'm working in RST2013, but this may apply to all flavors of Revit.
I currently have a project, with three linked files. In a Braced Frame...November 30, 2012, 07:14 PM -
Good evening RFO readers.
I have a problem regarding view. My structural framing are cutting floor and as you see in the picture black lines appears....November 18, 2011, 12:34 AM
