I have modelled up a facade cladding/fin component that stretches 8 floors. The problem I'm having is that I can see parts of the component that are on the 2nd flr etc. Is there any way of limiting / controling the amount of component I can see?
controlling model component view range
What category did you model the cladding/fin in? Probably one of the non cut-able (like specialty equipment)... Try changing it to a cut-able category (like generic)
And is it an in-place or a loadable family? Could also be your setting in the Element Visibility Settings...Klaus Munkholm
"Do. Or do not. There is no try."
Could you post the family/project? Did you use a Curtain Wall or another category? Was it In Place or Loadable?
Ergo: more details please...Martijn de Riet
Professional Revit Consultant | Revit API Developer
MdR Advies
Planta1 Revit Online Consulting
Have a look at Jason's post on his blog. It isn't an answer but it will give you insight into how choosing categories affects display. I believe your use of panels in this case is related though. Also I believe only family view range settings in Windows and Doors affect View Range directly in the project setting (meaning the family setting is acknowledged by the Revit project file), I might be forgetting another but if there is it's probably the generic model category. Bottom line, very few provide family specific control of view range apart from the project behavior.Last edited by Steve_Stafford; August 22, 2011, 09:30 PM.
Still struggling with Revit...
Trying to create a family in "Generic Model" category then come up with a view issue. Below is front...-
Channel: MEP - Family Creation
May 3, 2021, 02:57 AM -
I have not noticed this before but I've encountered a problem but others have. While in 3D view, everything is visible. In the reference plan view, nothing...
Channel: MEP - General
November 30, 2015, 04:04 PM -
Is there a way to have exceptions for view range settings in a certain view? For example, I have an equipment plan. I want all thing that are in the category...February 25, 2019, 08:29 PM
Is there a way to quickly find out what Model Category, Annotation category etc that an element/family falls into? For example, we have a ton of view...September 26, 2017, 09:40 PM
Hi
I'm kind of new to revit - i have a family that I want to show differently depending on the view.
it's something really simple but I am...-
Channel: Architecture - Family Creation
February 27, 2013, 06:19 PM -
Monumetric Footer In-screen
