is there a way to do this with Revit 2017
Transferring just one View Template from Project to Project
We have view templates, not the views themselves, that I want to transfer.
To clarify, this is quoted from another post from 2013:
Let’s say you have 100 view templates in a project, and you make a new one. You want to transfer only that new template to another project (not the other 100 View Templates). If you use Transfer Project Standards (on View Templates and Filters), you will get the lot. How can we transfer just one of them?Last edited by katewood1989; January 31, 2017, 07:50 PM.
Originally posted by katewood1989 View PostWe have view templates, not the views themselves, that I want to transfer.I'm retired, if you don't like it, go around!
Pretty messy, but you could transfer from the original project to a blank project, then delete all but one, then transfer into the new project.
Or, I believe there are some 3rd party apps that allow you finer TPS control.Dave Plumb
BWBR Architects; St Paul, MN
NICE!!
One (big) step beyond what you are looking for is View Filter Manager: https://www.revitforum.org/commercia...tml#post169061
Looks pretty handy.
I've always used Revit Lookup where you can select anything in your project by ID. If you do a quick google you'll find compiled installers.There are no stupid questions, only stupid people
I have tried transferring my view templates from one project to another by following the procedure from the Revit help menu without luck.
Channel: MEP - General
January 20, 2014, 02:00 PM -
We use the 'insert views from file' command to bring our standard details into a project. However, the inserted views don't seem to bring the applied...May 15, 2017, 11:04 PM
Think of this scenario - you have 5 different Revit projects all linked together in various ways. You want to ensure that there is some consistency in...
Channel: Blog Feeds
May 27, 2012, 11:45 PM -
Is their a quick way to copy and paste filters i've selected from one view template and paste into another without me having to select them all again...May 17, 2016, 02:20 PM
If your Manage View Templates button is disabled it means that you've got no view templates to manage. That troublemaker "someone" deleted them...
Channel: Blog Feeds
March 6, 2013, 03:15 PM -
