TOpografy
    TOpografy
    Sorry about the second question!
    I have use split surface to change some heights of my topografy!
    Is there any way in a section to see the real topografy line in order to draw a line on top and schow how it was before?
    Thanks
    This may help you…
    Make Hardscape Follow Site Topography and Site Topography Follow Hardscape in Revit
      This is what i wanna do. If theres a way to hide the slpit surfaces because i moved the points in differnet level..see the real topografy level.. and draw it with a line like the blue line i have there!
      thanks
        Anyone with an idea maybe?
          You can try creating existing toposurface and put it under existing phase. Put the new one under New construction. Then manipulate with view properties line weight and other graphics?
          See if it works...!
          Sent from my iPhone using Tapatalk Pro
          " Purpose may point you in the right direction but it's passion that propels you" - Travis McAshan
            One topography as existing and one as proposed. Then choose phase filter to show existing, draw over existing, then turn phase filter back to proposed, ending up with detail line sitting over proposed. What i see as the best way of showing natural ground level/line, (NGL).
              THanks a lot guys!! It worked! Many many thanks!
              Loading...
