I'm finding people keep accidentally adding our floor slab into a group that repeats on every floor. when I find this I remove it from the group, so then there are multiple floors on top of each other. is there anyway to determine which is the original so I don't loose tags when I delete the copies?
How to tell what object is newer then another?
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None
that was my first thought too. What I realized I could do also was go to a view that had the floors tagged and delete one, if the tag disappeared, then that was the wrong floorScott D. Brown, AIA | Senior Project Manager | Beck Group
In case you run into that situation again...
If it's possible, I try to edit the element within the group first (to make it obvious - offset 4' from level, for example), close the group, then re-edit the group and remove the problem object. Now you can filter for objects that match what you just changed.Chris Ellersick
Originally posted by cellersick View PostIn case you run into that situation again...
If it's possible, I try to edit the element within the group first (to make it obvious - offset 4' from level, for example), close the group, then re-edit the group and remove the problem object. Now you can filter for objects that match what you just changed.Scott D. Brown, AIA | Senior Project Manager | Beck Group
I guess the confusing heading might need some clearing up.
Okay so the problem is that the project I have recently (3 working...November 17, 2014, 02:33 PM -
I have made a group for a floor panel. i have it all lined up properly and it has joist hangers. every time i copy the group the joist hangers change...May 7, 2013, 11:56 AM
Since we do a lot of multi-unit construction (apartments, hotels etc - usually 4 stories or less) I usually use groups for the units which works great...February 9, 2013, 10:04 PM
Hello everybody.
I'm new using revit and I am having some problems with a group that I created. I made a group of a Module that I...September 14, 2017, 06:58 PM -
Today, one of my Revit-saavy bosses asked me an interesting question. We have a potential project that would be a 6-story office building fitout. This...
Channel: MEP - General
October 8, 2015, 10:23 PM -
