SHow edges
    SHow edges
    Hey guys
    how can i bring this to its normal stage! I cant really choose the walls in my 38 and i see hidden lines or edges!
    ANd its notin wireframe
    Thanks!!!
    Two possibilities:
    One: it looks like that's an external view, so I wouldn't be surprised if there's a DWG linked in as topo.
    Linked (or - shudder- Imported) DWGs can often cause weird display issues like this. Try getting rid of the DWG & see if it still happens.
    Two: 3D Views can get corrupted. Try creating a fresh 3D View. You may have to delete the old one & just use the new.
    But my money's on the DWG
    Dave Plumb
    BWBR Architects; St Paul, MN
      Thanks a lot! I deleted the defualt 3d view ! And open again another view! it worked!
      But now wenn i press on the 3d button i can see a default view on my list!
      How can i make a new default 3d view? I mean not a camera view
      Thanks again
        Just rename it to something else, and a new default view will be created.
          YEap when i press the 3d button on my project browser i dont see any 3d view witch is bold..
          i just see my old camera views! so how can i renaim it!?
            Still didnt find a way to fix it.. i deleted the default (3d) view from my Project Browser 3d VIews..
            I click in the menu VIEW and after on the 3d default button... I enter in the 3d modus but on my Project Browser 3d VIews.. i cant see any 3d view in Bolt...
            SO i cant rename it? ANyone knows why?
            Thanks in advance
              Check to see if you have a filter applied to your project browser...
              You should see {3D} under the 3D Views category. You can right click and select rename to something else. The next time you click the 3D button in the toolbar it will create a new {3D} view. When working on a workshared project it creates views like {3D}-username.
