Hi every one i wonder how i can create this ornamental above wall or floor can i create rectangular wall then substract and if how by steps please or if there is other method please guide me and thanks for help
question in substraction to create form ?
Draw the wall to base height (bottom of ornament). Go to Elevation View. Select the Wall > Edit Profile. Sketch the ornament.
Now stay in Elevation View. Home > Model Line. Use the Pick Line tool to draw Model Lines which follow the profile of the Wall.
Create a Profile for the stone layer on top of the wall. Simple parametric rectangle will do. Load into your project.
Roof > Fascia. Create a new Fascia Type, apply the Profile you just created and use the Pick Line tool to select all the model lines and create the Fascia.
And dude, find something easier to start with!!! Get the basics first and then start :banghead: on this.Martijn de Riet
Try the HELP menu for some of your questions. In Revit, go to Help, or press F1. Or browse to: http://wikihelp.autodesk.com
Here's a link directly to an answer to your question:
http://wikihelp.autodesk.com/Revit/e...34-Editing_334
thanks all of you are helpful and i appreciate it
it reminds me with archicadtalk forum i was have about above 120 questions in the first with following some tutorials in graphisoft i become perfect in archicad
this forum is helpful and encourage me to make a move and revit is more promising
Hi guys, I'm new to Revit and would like to create a sloping wall that is rounded in one of the corners. I have been able to define the profile, or get...June 3, 2014, 06:56 PM
Damnit spent like 2 hours trying to make something, i need to make wall as it shown on picture, but how can i make it? to the ramp i cant attach it, to...May 11, 2011, 10:24 AM
hello,
do you guys know how to make random screening wall in revit?
or- any suggestion how to do it?
thanks!...December 20, 2013, 02:49 AM -
Hello everyone,
I'm new to the forum and pretty new to Revit but reckon im gona be using both very often from here on in!!
...September 5, 2011, 09:52 AM -
Hi guys, is there a good way to have a proper finition like this wall? (exterior cladding)
I tried with a profile, but the profile was working weird...September 29, 2020, 03:27 PM
