We have had two recent projects where our wall tags have disappeared when printing to pdf, and we did not catch it before we sent it out to bid. Has anyone else had this problem?
Thanks,
AAron
What version of Revit are you using and what is the current service pack level? There was an issue at one point with 2017 I believe and a quick service pack update fixed this. But that was right after 2017 was released, so it shouldn't be an issue unless your Revit is not updated.
If you think you're going crazy because no padlock appears when you try to align and lock a Wall by its Core Centerline, you're not crazy (not about that...
Just been made aware of a surface pattern problem on a project, where a wall is correctly showing brickwork on the 1st floor but vertical lines on the...
