Hi everyone!
First post on this forum so be kind please!
I tried to look for a similar case in other posts but I didn't succed.
I am currently working on my first project on Revit Architecture: a wooden structure with a simple geometry and ordinary roof.
My issue is related to the connection between roof and walls as in the attached image (exported from a reference CAD file).
I was guessing how to model the connection since structural parts (the beam and the x-lam layer) and architectural ones are not alligned.
Here some of my consideration:
1- Would be a smart solution the one which considers the creation of two different walls (EXTERIOR CORK FINISHING | STRUCTURAL X-LAM) with the first one reaching the final height over the gutter?
2. With regards to the roof: I was wondering if a double roof would solve the different alignment between |structural beam+wooden panel| and the |insulation+cover finishing| layers. The first one starting from the wooden panel quota and the second one from the top of the wooden panel.
3. Lastly: how to model the gutter? Maybe is a better idea to avoid its modelling and let an empty space on top of the structural wall?
Thank you for your time in reading!
