I am having issues with my matchlines crossing over dimension strings in my large scale views, and not able to find a good solution,..YET. Currently, I am separating matchlines to individuals, spitting them into different aligned segments, and finally hiding the segment that crosses over a dimension string. Has anyone else seen this issue noted in the attached images?
Annotation Crop and Matchlines
Originally posted by DaveP View PostWait until you do a Callout that crosses over two Zones.
OP, I use opaque dimension strings in this situation. Not ideal, I know.Attached Files
When a crop region is split and there are dimensions spanning the two halves of the crop region it will not let you drag the dimension text anywhere....March 27, 2013, 11:58 AM
For some reason, it seems as though the annotation crop is not working. I have sections going outside of the crop region and I am not sure why. How can...December 2, 2019, 07:44 PM
Just found out you can actually dimension the crop view to practically everything within that view. No more eyeballing to create views of consistent width/length/height....
Channel: Tutorials, Tips & Tricks
April 4, 2014, 12:02 PM -
How are the annotation crop extents determined? I have a lot of scope boxes in my current job for enlarged plans, rotated areas of the plan and so on...June 12, 2014, 07:10 PM
I just filed this Service Request, but I thought I'd throw it out here to see if you guys can beat Autodesk.
Not sure if this belongs...February 28, 2012, 09:48 PM
