I have a structural column and have modeled the corbel to the column as a structural connection.
When show hidden lines is set by discipline the column on plan has hidden lines however the corbel there is is no hidden lines.
To show the corbel in hidden lines I can either change the show hidden lines to all or use the show hidden lines command.
Another work around is to use a beam instead of structural connection this will display the hidden lines.
Is there a way to control the hidden lines for the corbel (structural connection) so that hidden lines display by discipline?
