Hi there!
Is there a way to set a family, for example door, to have specific parameter setting in each view?
to illustrate the scenario:
I have three views:
1. plan
2. elevation
3. spot perspective
now I have a door with two different graphic form -- one is open, one is closed. This is done by having two models of the door panel in open and closed form each controllable by a yes/no parameter i made as instance.
now I need the "open" form in plan (i cannot use symbolic lines to denote opening since the project requires the door to cast shadow in plan)
and i need the "close" form in elevation.
--easily though, i have set the involved parts in visibility settings of which of them should not show in plan and elevation.
BUT THE PROBLEM IS, WHEN IT COMES TO 3D VIEW. There is no available/tickable setting for 3d view in visibility setting, the creation of yes/no parameter was mainly for 3d presentation as i need to show some shots where the doors are closed and some shot where the doors are open and a mix of open and close in one shot.
now each tick of visible (yes or no) in parameters affects my other views.
sorry, I hope I have explained the scenario well.
Thanks!
I have three views:
1. plan
2. elevation
3. spot perspective
Thanks!
