Panel Schedule Templates
    My question is, I am trying to create a one column branch panel schedule. I seems that the only panel schedule that is created is a two column, circuits across schedule. I have exhausted every option that Autodesk has to offer and tried a few trial and errors on my own but the end results is that when I select create a panel schedule I always get the one option mention above.
    Other than explain everything I have tried over the last 4 hours, maybe someone out there has a simple direction for me to try.
    Thanks, Keith
    This is something that should be posted in the MEP section of the forum it would get a better shot of having people in the electrical field look at your question there
      I realized that after I had started the thread. I was new to the site and really did not know what I was doing. So If this thread can be deleted I will be okay with that because I have an identical thread started in the MEP section.
      Thanks Darius
        Thanks Darius
        Keith, I'll delete the other one since this is now a thread...
