Hello,
I want to give a Code Number to the Elements in our project and I think the best way is That to Create A shared parameter. I have two questions:
1. Do you believe That is more preferable to use the classification system already HAS That Revit (OmniClass / Keynotes / Assembly Code)?
2. Do you know if / how I can create tags with description for each code. I mean that I want when I choose an element to be able to see the code with a description for this element.
I hope to make sense The Above ..
Thanks in advance!
Thanks in advance!
