any one know how to detect cable tray in edge wise because in the soft ware i found only duct and pipes for MEP but i want it to detect the cable tray and draw it.
Edgewise data base problem
Don't know how much traction you will get here regarding Edgewise. The downside, as I'm sure you have figured out, is you cannot swap between cable tray and duct/pipe in Revit.
You could very easily detect the cable tray as a duct. Bring the Duct into Revit. Use Dynamo to get the centerline of the duct, create cable tray from centerline of duct, then adjust height to match real-world height.
Just a thought.
Originally posted by kraftwerk View PostDon't know how much traction you will get here regarding Edgewise. The downside, as I'm sure you have figured out, is you cannot swap between cable tray and duct/pipe in Revit.
Just a thought.
Do any one know how to convert duct to cable tray , I face serious problem that i received a model and find a lot of routing presented in form of duct...
Channel: MEP - General
January 15, 2017, 09:27 PM -
hi
Bus duct is similar to cable tray and duct. But not its profile and parameters.
My concern is we cannot edit system...-
January 19, 2016, 05:11 AM -
What's the best way to place clearance for cable tray? I wish cable tray had an option similar to piping insulation except it added clearance space....
Channel: MEP - Family Creation
May 21, 2015, 02:22 PM -
Being New to Revit i am finding how to draw cable tray, can anyone tell me best way to do this
you have say a run of 2 main cable trays running...-
February 20, 2015, 10:55 AM -
I'm new to Revit and can't find any information on handling noise barriers in cable trays. Seems like an important item to have in a cable tray design....
June 13, 2017, 12:46 PM -
