Do any one know how to convert duct to cable tray , I face serious problem that i received a model and find a lot of routing presented in form of duct family and in real it is cable tray so i need to change all these routing to cable trays without remodeling again.
Duct to cable tray conversion
You might find a solution to this on the Dynamo forum. I know there was already some work done on converting model lines to pipes/ducts and the principle would be the same for Cable Trays."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
- Likes 1
Red3 The attached dyn script creates cable tray segments in place of the duct segments. The segments then need to be connected manually or you can try to improve the script (find how to lengthen the lines of the duct segments so that they connect if connected by fittings). Also, the height and width of the tray is set inside the script for an example, this can also be improved.
- Likes 2
any one know how to detect cable tray in edge wise because in the soft ware i found only duct and pipes for MEP but i want it to detect the cable tray...
Channel: Coordination Tools
January 15, 2017, 10:31 PM -
What's the best way to place clearance for cable tray? I wish cable tray had an option similar to piping insulation except it added clearance space....
Channel: MEP - Family Creation
May 21, 2015, 03:22 PM -
how to make left side and right side cable tray reducer in revit-2017
:bb:
please help me. I'm new revit user-
Channel: MEP - General
June 10, 2016, 12:02 PM -
I'm new to Revit and can't find any information on handling noise barriers in cable trays. Seems like an important item to have in a cable tray design....
June 13, 2017, 01:46 PM -
Being New to Revit i am finding how to draw cable tray, can anyone tell me best way to do this
you have say a run of 2 main cable trays running...-
February 20, 2015, 11:55 AM -
