revit tile floor patterns
    can't seem to get 2 different tile floor pattern in a bathroom 12x12 with 2"x2" in shower have duplicated several different times, but even so it is either 12" or 2". Even when I make separate floor structures. what am I doing wrong...?
    Did you create two different materials and assign them to the correct floor?
      Thank you MP, thank you for always taking the time to be helpful, I changed the 12" ceramic tile to 12" vinyl composition.
      It worked, but still seems like u ought to be able to duplicate and rename to 12" ceramic tile and have the size on one portion of the (the portion selected ) change .
        If you duplicated the material you need to also duplicate the asset, otherwise changing one material changes both.
          how do you duplicate the asset? probably a dumb question.
            Use the duplicate asset button on the top right of the material window. You can see if there are other materials using the same asset by looking at the number I've put a red rectangle around. If this reads anything else than 0, that means that you would change another material (or several, depending on the number) as well.
