I'm having an issue getting a shared & nested window sill to cut my watertable that is on a brick wall. The nested family will cut the wall correctly but the wall sweep hates it and refuses to cut appropriately. I'm sure the answer is something simple but I'm stumped currently... Any thoughts?
Nested Family not Cutting Wall Sweep
In your sill family uncut a host(face) with a void so it will not cut it and reload a family, now use Cut tool and the window will cut off a part of the wall sweep.Revit add-ins: Purger (delete UNUSED and selected line patterns & line styles, find & delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager (with bunch of other features) at Autodesk App Store, View Filter Manager ML, SolarDaylight
Originally posted by Artejon View PostIn your sill family uncut a host(face) with a void so it will not cut it and reload a family, now use Cut tool and the window will cut off a part of the wall sweep.
Originally posted by PijPiwo View PostEdit your sweep profile (watertable-rectangular-profile.rfa) so it is below center(front/back) ref plane, not above and relocate wall sweep in the project as needed.
Thanks for the feedback so far - I'll keep trying :beer:
edit: PijPiwo's solution worked, it just required setting the sweep to not cut by inserts :crazy:Last edited by cellophane; January 16, 2017, 03:35 PM.
Originally posted by cellophane View Post/shrug
One more question now - If I adjust the profile with the proper profile (sloped for water shedding) the top of the wall pokes through. Any ideas on that one?I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postmodel your wall the correct height? :hide:Last edited by cellophane; January 16, 2017, 09:23 PM.
I created a family for my drop box. The family only cuts the sweep where the trim around the box is. The center doesn't cut. I used a void for the...
January 20, 2011, 04:50 PM -
what is the difference between cuttable and cut wall options in wall sweep?September 29, 2012, 10:39 AM -
I made a wall where I added a few wall sweeps. (edit type > structure > edit vertical structure)
When I cut a hole into the wall profile...April 27, 2018, 05:55 PM -
It used to be when you added a wall sweep to the wall, it would automatically cut at openings and if you need to adjust it further there were little blue...April 12, 2011, 01:08 PM
Hi Guys / Gals,
We have created a hosted profile to be used as a flkoor thickening to our slab under internal walls. W have used this profile...May 3, 2013, 04:13 AM
