IFC4 export options
    IFC4 export options
    Hi, i want to export data using IFC. Revit is IFC4 compatible for some time now according to some documents.
    How is it that i can't see this in the export options list. In release 2016 this is exactly the same as 2014 and 2015
    What is the 'version 4' part in it? Any experience that 2016 gives better ifc output than 2014?
    Download and use the "Alternate UI" (produces by Autodesk) downloadable from the App Store:
    It replaces the OOTB one: IFC updates are controlled with this, instead of with Revit updates
    Alex Page
    RevitWorks Ltd
      I downloaded it and noticed the export options are very different now.
      However, if i exported a model containing rebar as ifc with a view different setting and somehow the rebar element are not coming through in the ifc textfile as result. What options control this? thanks.
        Is "Structural Rebar" is actually getting exported in your IFC Settings?:
Name:	ifc options.png
        Alex Page
        RevitWorks Ltd
          Strctural fabric reinforcement IfcReinforcementMesh
          Boundary IfcReinforcementMesh
          Fabric wire IfcReinforcementMesh
          Structural path reinforcement IfcReinforcingBar
          Boundary IfcReinforcingBar
          Stuctural Rebar IfcReinforcingMesh
          Hidden Lines IfcReinforcingMesh
          blabla .. the defaults ..
          Any checkboxes here that 'has left the building'.. ?
