It's easy to add parameters (either current or new ones) to a Tag (provided they are Shared Parameters.)
However, I suspect what you're really asking is "Can I pull the Materials from the Floor, Walls and Ceilings that define a Room's boundaries?"
And to that question, the answer is "No".
I don't know the programming reasoning behind that, but my guess would be that a Room can be bound by more than 4 Walls, Floors extend over many Rooms, and you may have several Ceilings in a Room
Dave Plumb
BWBR Architects; St Paul, MN
Is there a way to allow room tags to be farther outside a room without a leader needed? I want to be able to move the room tag farther away from the room...
this is the last task for my family..ive done all of the required task except for this annoying room tag.i made some room tags for the project.the goal...
