What is going on here? When I bring the family into my Revit file it will host only on walls, or the sides, but not the top, of the plinth I've drawn.
Floor based Pumps appearing only on walls
There are a few possibilities:
-Wall or Face based. It will only place on faces of objects and not on floors in floor plan views. In the task bar there should be the option to choose if you want to place it on a Workplane (the level) instead of a face.
-Workplane based. Work exactly like Face based, except that if you go in the family and uncheck the 'workplane based' tick box it becomes a normal level based family
-Level based. Can always be changed back to Workplane based if required.
So my advice is always use Level Based (the 'normal' family template) and if you have manufacturers families that are set up differently, put them inside your own standard template family."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Originally posted by MassiveGhoulDuck View PostYes, i can make my own, or modify the manufacturers one i was using to save time.
But i think its important to understand why a problem occurs, and it makes me wonder why you bothered responding if you dont have the answer.
Also be sure you are using the MEP version of the family and not the Arch version, as MEP versions are face based or level based, like Joseph mentioned.Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by MassiveGhoulDuck View PostWhat is going on here? When I bring the family into my Revit file it will host only on walls, or the sides, but not the top, of the plinth I've drawn.
Hi there,
I have created a family using the floor based template.
But, I would like to place it on the roof also. Is it possible...September 17, 2016, 07:01 AM -
This may be dumb question, but when I'm creating a face based family that is meant to hang from above, I have to model it upside down. Is there any way...
April 26, 2011, 08:49 PM -
Hi All,
I have downloaded a split type indoor unit from a manufacturer website. The family is in mechanical equipment category and not face/wall...-
Channel: MEP - Family Creation
February 7, 2013, 03:51 AM -
I know how to convert a wall or ceiling based family to a face based family.
but I have a family that is not hosted (blank for the host)....-
September 30, 2016, 02:01 PM -
Is there a relatively simple / easy method to take a family that is created with a host (wall, face, etc) and make it un-hosted without having to recreate...November 24, 2015, 06:06 PM
