Dynamo for Rebar installation problem
    Hello everyone.
    I am trying to install package Dynamo for Rebar manually by placing the extract zip file in folder C:\Users\Minsc\AppData\Roaming\Dynamo\Dynamo Revit\1.2\packages and I have no result.
    When I examine package version 1.2 and older I see that folder Dyf in which custom nodes should be placed is empty. If someone can explain me the process of installing it manually step by step I would be very grateful.
    Thanks.
    Solved. It seems that windows was blocking some .dll files in bin folder. I just unblocked them in the properties... and apparently in some packages dyf folders are empty depending on how the custom nodes were created.
